SKY + HD, with onkyo 605 what connections!? any help must appreciated
henxuk
19
Hello all,
Haven't posted here for a while and need some help.
I have just got sky+ HD and was wondering, do I connect, (Onyko 605, pana 42 th42pz81b, mission M cubes, PS3)
an HDMI cable from sky HD to onkyo input 1, ps3 with an HDMI to input 2 on the amp, AND THEN
from onkyo out an HDMI cable to the input of the TV.
OR can I just get away with connecting the HDMI cable from the sky HD box straight to the TV and using an optical
out from the tv into the amp, ( with the ps3 connected to the input 1 of the amp with an HDMI cable from the amp out into the input 2 of the TV)
PHEW
Just wondering which was a better bet
Thanks a lot guys
d4v3pum4
40
Regardless of whether you route the video (+stereo audio) via the amp using HDMI, you need a separate digital audio connection to the amp to get Dolby Digital 5.1 from selected programmes and movies. Sky+HD only outputs stereo over HDMI.
henxuk
19
damn well now I'm really confused so what I need an hdmi from then sky to the amp with ANOTHER cable from sky to amp just for audi!o??
this doesnt sound right
is the sky hdmi to tv and optical from tv to amp no good?
henxuk
19
what about if I want sound from the tv through the amp? freesat or suchlike
I think my amp (605) only has one optical input ? :(
henxuk
19
sorry , I just mean what cable I need,
I think I need ,
1) hdmi from sky to tv
2)sky optical to amp
3)hdmi from ps3 to amp
4) hdmi from amp to tv
Andrew Everard
1,878
It means some Sky HD boxes offer a choice of optical or electrical digital outputs, and you can use either.
And that the Onkyo has two optical digital inputs and two electrical digital inputs.
Andrew Everard
1,878
henxuk:
I think I need ,
Yes, and if you want to run the Freesat sound from the TV to the Onkyo, another optical lead (if that's the kind of digital output the TV has) from TV to amp.
henxuk
19
right, I see, and a standard toslink optical cable will fit these electrical digital inputs yes?
I can seem to remember seeing the connections at the back of the amp
henxuk
19
brilliant Andrew, you a guru of gurus,
and yes my panasonic only has one sound output option
- a optical toslink out :(
at least I think it only has that one
th42pz81b
Andrew Everard
1,878
henxuk:right, I see, and a standard toslink optical cable will fit these electrical digital inputs yes?
No, the toslink only fits in the optical sockets. For the electrical digital connections you need a 75ohm digital cable, with phono plugs on each end, like this one.
And yes, the TH-42PZ81B has an optical output
henxuk
19
RIGHT, I think I got it so I could use either optical or these electrical jobbers.
And I'm guessing the electrical ones are better than optical?
Andrew Everard
1,878
Urwire?
Is that this one...?
