davedotco said:
The UD-H01 is actually a very nice bit of kit, but despite all the BS regarding it's state of the art 32 bit chips and whatever else it has, it will not audition as significantly better than what you have.
Look at the casework, connectors, onboard power supply etc, etc, that is what you are paying for and that costs.
It would be even better if it had level control on its line outputs so it could be used as a dac/pre-amp but it doesn't, it misses the mark.
The UD-H01 is actually not half bad. It doesn't provide variable output RCA connections because it's thought out as a headphone amplifier rather than as a preamp. It wouldn't be my choice either, but I wouldn't doubt for a second that it'd be an upgrade over the Behringer. It doesn't miss any mark, you are just judging it out of context.
You keep on claiming that the Behringer is all anyone needs as a DAC. Still, all the DACs you mentioned here that you have listened to are, technologically speaking, very similar to one another—often outdated and of the cheapest variety. Saying that the Behringer can hold its own, and saying that it'd be difficult or much more expensive to get better sound, are two very different things in my opinion. Well, a jack out of my computer straight into an integrated doesn't sound bad at all either, and clarity is decent at half volume—but it would still not occur to me to state that that's enough to get top-notch sound when using the computer as a source.
DAC chipsets themselves have not changed so much for some time—but the technology employed to connect them to computer audio sources, for example, has. I'd suggest you do yourself—and the people you advice to here—a favour, and listen to more advanced digital stuff before making so absolute recommendations. I believe you'll find that things have changed a lot since the times when you used to work in hi-fi.
