just got the Panny G20, what are the best settings for it.I have a Denon 1910 amp,sky hd & Sony 360 bd player + PS3,im using QED hdmi cables & i sit 4m from tv.
First I would suggest you use the THX setting out of the box, then with a disc like Star Wars set the tv up using the THX setup this found in the language section of the disc.
Or alternatively before or after the above you could try the settings below found on the internet after the TV had been callibrated.
Mode THX
Contrast 36
Brightness 0
Colour 30
Sharpnes 0
Vivid Colour off
Eco-Format off
P-NR off
Intelligent frame ON/Off
Panel On
R-gain +3
G-gain -2
B-gain 0
R-cutoff +2
G-cutoff -1
B-cutoff 0
Hope that helps resolve you problem.. Regards ..Paul
EDIT:- Just to add you may have had a better response if you had put this question in the TV's and Projectors or Home Cinema Forums.
