Dinglebin
Slightly off topic here guys. 46F8000 arrived from JL last week and I've patiently been waiting for the Samsung WMN250M mini wall bracket to arrive. It landed yesterday (well I thought it did) after opening the packaging and contents I discovered that I'd been sent the WMN350M instead. Packaging and product appears to be more or less identical to the 250M albeit the instructions state you can't fix the F8000 at the closest position to the wall 17mm. Instead it states you have to fix it 40mm away using spacers provided with the tv. Before purchasing I read lots of reviews about the 250M kit which people claim to have used at the 17mm close fit. Ie without the spacers. I tried to not use the spacers with this kit but the screws are too big for the back of the tv which forces you to use the spacers!!
What wall mounts have you guys used for this TV? I'm trying to get a close fit but need to be careful because my cable access point and switch fuse spur are located in the centre of where the tv will be positioned on the wall I between the camera and the deep section on the bottom half of the tv.
Also I thought the tv was VESA 400 x 400. The wall mount template shows it as 200x200??? Anyone confirm this?
thanks Darren
thanks Darren
