Me too, I have pre-ordered the Panasonic for £539, history suggests it will be more reliable than Samsung based on past players.simonlewis said:Which one are you buying ?
I think i will go for the panasonic !
Are you going to pre-order the Panasonic then or wait until it comes out?simonlewis said:Which one are you buying ?
Did you have any issues with your Samsung player?gel said:Me too, I have pre-ordered the Panasonic for £539, history suggests it will be more reliable than Samsung based on past players.simonlewis said:Which one are you buying ??
Nope, it was the first generation I was referring to. Mine is really good.bigboss said:Did you have any issues with your Samsung player?gel said:Me too, I have pre-ordered the Panasonic for £539, history suggests it will be more reliable than Samsung based on past players.simonlewis said:Which one are you buying ?
Ah cheers. I will probably get a call as I put myself down on the pre-order list. *smile*simonlewis said:I think samsungs blu-ray player will go live on their website tomorrow and best av deals will probably be advertising it.
gel said:Nope, it was the first generation I was referring to. Mine is really good.bigboss said:Did you have any issues with your Samsung player?gel said:Me too, I have pre-ordered the Panasonic for £539, history suggests it will be more reliable than Samsung based on past players.simonlewis said:Which one are you buying ?
Where did you pre-order it from?simonlewis said:Anyone wetting their pants at the thought of the launch of these players, i know i am i have already pre-ordered the panasonic yesterday. *good*
gel said:Where did you pre-order it from?simonlewis said:Anyone wetting their pants at the thought of the launch of these players, i know i am i have already pre-ordered the panasonic yesterday. *good*
*good*simonlewis said:gel said:Where did you pre-order it from?simonlewis said:Anyone wetting their pants at the thought of the launch of these players, i know i am i have already pre-ordered the panasonic yesterday. *good*
Superfi
Have you got your 4K HDMI cables yet? Do you do 4K on Netflix?simonlewis said:gel said:Where did you pre-order it from?simonlewis said:Anyone wetting their pants at the thought of the launch of these players, i know i am i have already pre-ordered the panasonic yesterday. *good*
Superfi
bigboss said:As I have said before, check if your existing cables work first. You may find that existing cables already exceed specs and work with 4K as well.
*good*bigboss said:As I have said before, check if your existing cables work first. You may find that existing cables already exceed specs and work with 4K as well.
Ah, okay. Cheers!simonlewis said:Not sure what my cables are to be honest they are quite old, i'm pretty sure you get a free one with the panasonic UHD blu-ray player, no i don't do 4K netflix i haven't got an account/subscribe to them.
gel said:
ellisdj said:when are these players released?
