SACD Compatible 3D Blu-ray Player
John Hereford
Does anyone know whether there are any reasonably priced (up to £300) 3D enabled Blu-ray players, that can also play SACD's, on the market that have either 5.1 analogue audio or twin HDMI outputs, for use with my ageing A/V receiver? Any help would be appreciated.
f1only
278
May be worth a look at the Pioneer LX55 & probably nearer your £300 budget
It doesnt have the analogue out requested but does have the 2 hdmi & plays SACD.
Regards ...
dontlaugh
10
Have a look at the Sony BDP-S480 which you can get for well under budget at just £99 from Richer Sounds at present. Don't know if it has twin HDMI outputs but it will certainly do 3D Blu-Ray and also SACD (through the HDMI as it has no multi-channel output).
Maybe this releases enough budget for a receiver upgrade!
It seems to get very reasonable reviews.
Also available at many other stores if Richer Sounds are out of stock - but at a slightly higher price of course.
John Hereford
Dear All,
Thanks for your suggestions. On reflection, I think I will go down the cheaper Blu-ray (Sony BDPS480 or 580) and replace my A/V receiver with a Sony STRDH820. Happy New Year to you all.
