SACD and MDac
I just went and bought my SACD player (actually, a budget Blu Ray player, the Sony S485). Immediately connected the Coaxial out of the BluRay player to one of the Coaxial in ports of the MDac, which is in turn connected to my Naim XS. The SACD I am plaiyng is Dianna Krall - The Girl in the other Room. When I play this SACD, the display in my Mdac shows as "16 bit/44.100k" which is the same as for a normal CD! Am I doing something wrong?
chebby
1,255
27
19,220
On my Sony I would have to go to...
'Music Settings' ('Help' on remote, then left arrow until you get to the toolbox symbol, then down arrow to 'Music Settings').
Then select 'Super Audio CD Playback Layer'
Then toggle from 'CD' to 'Super Audio CD' and select.
The_Lhc
1,176
Does that actually output through the coaxial or is it only through HDMI to a suitable DSD-friendly receiver?
Clare Newsome
1,657
IIRC, some 'universal' players will output SACD over coaxial/optical, but a) as noted by Chebby, you'd need to select that option and (b) the signal will be downsampled to 16/44, and be stereo only.
chebby
1,255
27
19,220
I surmised that the OP's SACD signal is outputting through coaxial, as he is listening to it through his coax connected DAC (albeit in CD quality).
I figured that it may just need pointing to the right layer on a hybrid SACD.
The_Lhc
1,176
No surmising needed, that's exactly what he said but if, as Clare suggests, the player will downsample the output to 16 bit regardless of which layer is being read then it's not going to help him much.
Thanks Chebby and everyone else.
Are you playing the SACD through your HDMI port or via COaxial? When I play via HDMI, I have to go to HOME/Audio Settings/ DSD output mode/ ON
At least that's what the manual says I should do.
BUT, I want to play SACD not via HDMI but via Coaxial through my MDac to my Naim XS (I have a budget AV setup and the idea of buying an SACD player was to improve on the quality from my stereo system).
So when going through the coaxial to a stereo amp, the manual gives some options (I am just copying from the manual below):
BD Audio mix setting: outputs th audio obtained by mixing the interactive and secondary audio to the primary.
Dolby Digital
DTS
DTS Neo:6
Audio DRC
Downmix
To get the most out of SACD, usng my stereo kit, what should I choose?
This is exactly right! But how on earth do I point to the right layer on the hybrid cd, I am lost :-(
Thanks Clare. I sure hope the 5 star rated S480(/485) is not one of those 'universal' players :)
The_Lhc
1,176
Erm, Chebby's already told you how to do that in his previous post, now highlighted in bold.
Those settings in Checbby's 390 are not there in my 485, here is what I get:
DSD output mode (HDMI only)
BD Audio mix setting: outputs th audio obtained by mixing the interactive and secondary audio to the primary. (HDMI only)
Dolby Digital
DTS
DTS Neo:6
Audio DRC
Downmix
The_Lhc
1,176
That's because you're in AUDIO settings, you need to come out of there and go into MUSIC settings, which, according to page 26 of the manual, IS on your BDP:
[Music Settings][System Settings]x [Parental Control Area Code]Playback of some BD-ROMs, DVD VIDEOs, or Internet videos can be limited according to the geographic area. Scenes may be blocked or replaced with different scenes. Follow the on-screen instructions and enter your four-digit password.x [BD Parental Control]Playback of some BD-ROMs can be limited according to the age of the users. Scenes may be blocked or replaced with different scenes. Follow the on-screen instructions and enter your four-digit password.x [DVD Parental Control]Playback of some DVD VIDEOs can be limited according to the age of the users. Scenes may be blocked or replaced with different scenes. Follow the on-screen instructions and enter your four-digit password.x [Internet Video Parental Control]Playback of some Internet videos can be limited according to the age of the users. Scenes may be blocked or replaced with different scenes. Follow the on-screen instructions and enter your four-digit password.x [Internet Video Unrated][Allow]: Allows the playback of unrated Internet videos.[Block]: Blocks the playback of unrated Internet videos.x [Super Audio CD Playback Layer][Super Audio CD]: Plays the Super Audio CD layer.[CD]: Plays the CD layer.x [Super Audio CD Playback Channels][DSD 2ch]: Plays the 2ch area.[DSD Multi]: Plays the multi-channel area.
[Music Settings]
Andrew Everard
1,878
IME all these universal players will only output the CD layer via the S/PDIF electrical or optical connection, as much for copyright protection reasons as bandwidth considerations.
DSD layer audio can only be output using HDMI (which has built-in copyright protection handshaking), as DSD into a receiver or processor able to handle this, or converted to PCM for receivers without DSD capability.
Or some players offer the option of converting the DSD data into multichannel analogue audio within the player, and then outputting it via six (or sometimes eight) RCA phonos into a suitably equipped amp. All can also convert it internally and output it as analogue stereo, which is where downmix capability comes into play if the disc only has a DSD multichannel layer, and doesn't also provide a DSD stereo one.
[Music Settings]
Thanks! (*grins sheepishly*)
WHen I went to the Music settings, the SACD layer had already been selected. I guess it detects automatically.
On my AV setup, the SACD sounded a lot worse than playing it (as a CD) on my stereo setup (my av amp is Yamaha V671, speakers are cheap Yamaha ones).
The_Lhc
1,176
Well that's probably why. Can you run a cable from the output of the AV amp to your stereo amp to see how that sounds?
