rana_kirti:canada16:
What is the viewing distance?
From what you said so far I would say not really RX1 are more for a small music room.
Go for the RX6 you wont regret it
Viewing distance would be between 12 - 14 feet.
MUSICRAFT:rana_kirti:
Hi Fellow Members,
Hope you've all had a great start to the New Year...!!
I'm looking very keenly at the Monitor Audio RX line for my new 5.1 setup.
My Living Hall size in feet is....
Length = 19 feet ( 6 meters )
Width = 13 feet ( 4 meters )
Height = 9 feet ( 2.75 meters )
I'm looking at the RX 1 + RX Center + RX FX + RX W12 ( RX 1 AV Package ) The Setup will be used 100 % for Movies usage only.
Will the RX 1 be able to fill this room size ?
What say guys...?
Hi rana_kirti
The RX1's will be fine although i think if your budget allows then i'll have to go along with canada16's suggestion and also recommend the RX6's or even the RX8's as more suitable alternatives.
Btw, what AV amp will you be using with these speakers?
All the best
Rick @ Musicraft
I'd love to go RX6 but it's kinda above my budget Just trying to see if i can get by with the RX1 as the setup will be used only for 100% Movies usage only that too just once a week ( Coz i read they go down to 45 hz and the subwoofer is pretty awesome upto 21 hz so i guessed keeping XO at 80hz would be perfect ) If they can't make it in that room size then i can max stretch budget to RX 2.
Would the RX 2 cut it in that room size ?
or else i'll simply have to go with Bronze BX2 + BX Center + BXFX + BX Woofer. ( But just concerned with that tiny BX Center )
& Which AV amp will i be using....? lol.....
Rana
Hi rana_kirti
Fair enough.
The RX2's will bridge the gap by some margin. As good as the BX Series is please continue to consider the Silver RX Series as these are much better
Btw, i am waiting for you to tell us what AV amp you'll using. Go on i have faith in you
All the best
Rick @ Musicraft
