Roksan Rok One speaker cables
bignige
26
Hi
I have an old pair of Roksan Rok Ones and I am re-arranging my room and need longer speaker cables.
The current cable was bought years ago and the speakers need to be bi-wired I believe.
Any recommendations for a suitable cable that will not cost the earth please?
Nigel
insider9
740
301
5,270
To get the best advice can you clarify.
How long is the run? What amp/source/interconnects are you using? What cable have you used so far and did it sound ok?
Al ears
Moderator
bignige said:
Hi
Nigel
Please clarify (as above) why you feel they need to be bi-wired (a pointless exercise in my experience).
You would only need to bi-wire if you have lost the brass plates that connect the terminals on the back of the speakers. Are they still in place? Even then you could just use short wire connectors that can be purchased cheaper than a full run of bi-wire cable.
NSA_watch_my_toilet
7
If you don't have runs around and over 35 meters long, you will not need bi-wiring.
The same than above, I would simply see that the connecting wires are okay. If not, if your speaker is doing well without connecting brass/wire, don't add anything to that, it would just make the things worse.
Al ears
Moderator
I'm afraid bi-wiring has nothing to do with distance between the speakers. Your point regards the connectors however, does.
ASK THE COMMUNITY
