Can anyone help. I have a set of Rogers Studio 1 speakers
http://www.ebay.co.uk/itm/310900687875?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649)
Rogers Studio 1 Speakers. Exactly as pictured above - Below are more pictures that you can enlarge by clicking on them.
Good condition for their age. There are some light marks to the solid wood cases but nothing major. The speaker grills are very slightly bowed in the middle due to the material pulling the sides in, just about visible in the 7th photo above.To the back of each speaker right at the top there are 3 very small holes - These are pictured in the photos below.
The speakers come with two 'DIN' plugs that you can wire into your system.
As I'm sure you'll know if you're looking at these they were hugely expensive when new and are a very high quality pair of speakers. The BBC always used to use Rogers speakers due to their quality and longevity. They sound superb with that tone that you just don't get from modern speakers. Each speaker measures approx. 64cm tall, 30cm wide & 31cm front to back.
Had them running this afternoon along with a Quad 405 & Quad 33 Pre Amp which are also listed for sale. I also have some other audio equipment for sale so please take a look.
DELIVERY - PLEASE READ Please note that these finish on a Thursday evening. A courier will be arranged to collect on Monday so they're not sitting in some warehouse all weekend. Delivery via courier - Highlands & Islands inc. NI extra, please ask. Can deliver worldwide, if your destination isn't listed please contact me for a quote but being large & heavy it'll maybe costly.
European delivery quoted is for Western Europe only. - If you live in Eastern Europe, somewhere remote or on an Island it will me more. If you would like to collect then you're more than welcome however if collecting, cash on collection only please.
Any questions please ask.
Item Photos
click to enlarge
and a thorens deck
Thorens TD-160B MK II with custom plinth & upgrades
Taking my inspiration from ‘Inspire Hi-Fi’ of Chesterfield, I have carried out a number of upgrades to this classic Thorens deck which are detailed below.
The sound quality is now first rate with a real improvement in bass control and imaging. Very fine indeed.
To buy one of these decks with the SME arm and Ortofon 2M Blue cartridge and then have the Inspire HiFi upgrades, would cost in the region of £1000
Plinth
Custom built plinth made from 25mm European oak, finished with Danish oil
Oak spiked feet from Russ Andrews - work really well in isolating the plinth from acoustic feedback
Neutrik gold phono sockets - a modification of my own design. I have wired the SME arm to the sockets using fine circuit wire rather than using the heavy SME cable which interferes with the suspension bounce. The original cable is supplied and can still be fitted.
Suspension & sub chassis
LINN ‘Black’ springs and grommets from Russ Andrews with new, longer bolts - the LINN springs are a much ‘denser’ spring and bring more stability to the suspension
Double layer of cork sheet fitted to the underside of the sub chassis to reduce resonance
Bearing
I have fitted a PTFE bearing thrust pad supplied by SRM Techand have re-lubricated the bearing with their 'Black Oil' which contains Molybdenum Disulfide and Graphite.
Belt
Brand new OEM ‘Thacker’ belt fitted as used by Thorens in period
Arm and cartridge
The arm is an SME S2 improved with the fixed headshell and is immaculate.
The cartridge is an Ortofon 2M ‘Blue’ with just 50 hrs use.
Other
The acrylic lid is included with original hinges. You cannot use the hinges on the new plinth, but as these can be removed the lid can beplaced on the new plinth as a free standing unit
The original plinth is also included in the sale and is in fine condition (see archive image of deck before rebuild). There is a tiny 'dint' on the black alloy top-plate just to the right of the Thorens TD160 logo which is about the size of a pencil tip
but using a cambbidge audio preamp and NAD D 3020 Digital Amplfier / DAC
The Rogers speakers sound very quiet through this system. I presume it's the output of the amp??
I also have a Leak Studio 20 valve amp which needs a bit of TLC. Would that be powerrful enough if it was restored to power thorens to rogers via preamp?
I have no idea about the technical aspect of this stuff, obviously.
Dave
