Question Replacement remote for Denon TU1800 DAB
TomcatUK
11
I have just acquired a second hand Denon TU1800DAB tuner. I’ve just realised it doesn’t come with the remote.
Does anyone know if the remote for a TU1500AE will operate the basic functions (channel up/down; change band)?
Or can anyone recommend an alternative (apart from getting off the sofa to change things manually!!)?
Thanks,
TCUK
TomcatUK
11
I’ve never owned one, but I recently read that some learning remotes can be programmed from your PC, rather than copying an existing remote - which obviously you can’t do!
Thanks for the idea, I’ll explore that option.
iMark
454
234
19,270
What will almost definitely work is a Logitech Universal remote. We now have a Logitech Hub. We can control all devices, including a Amazon Fire TV stick, from iPhone and iPad.
