I have just bought a Rega RP3 and want to connect it to my Sony BDV-E300 home theatre system. Will I need a pre amp or will it connect directly to the Audio inputs on the Sony system ?.
If the answer is yes I do need a pre amp can you suggest a suitable choice ?
thanks
thanks
