I had trouble figuring it out too. Found a picture on eBay http://www.ebay.co.uk/itm/Rega-R1-Wall-Bracket-for-speakers-of-Rega-turntable-/181315049358?nma=true&si=wx%252FFY7Tzt5pwVfAVI8pEplGwYL0%253D&orig_cvip=true&rt=nc&_trksid=p2047675.l2557 it seems that the bracket comes in 4 pieces, 2 per speaker, one piece is fixed to the wall and the other to the back of the speaker. The 2 are then bolted together. Whether that's better than something like this http://www.amazon.co.uk/B-Tech-BT77-Ultragrip-Clamping-Loudspeaker/dp/B004DCAOHK/ref=pd_sim_sbs_ce_1 is questionable, especially if you don't want to make holes in the back of your speakers
