Hey guys. I just registered to post this thread since I am having a huge headache about my All-Rega setup. Additionally, I am from China - you know finding another rega user in China is like finding pandas, and the local dealer here is by no means more knowledgeable than I am... so i have to figure it out myself.
Half a month ago I bought a rega queen edition TT from a local dealer here in China. I connected it to the rega mini a2d phono stage, and then my Bose home theater. It sounded ok. A week later I could not torlarate the sound of Bose system so I bought the Rega Brio-R and a pair of Rega RS3.
Now my system is:
Rega TT - Brio-R input 1(with phono stage) - Rega Rs3
Sounds amazing. But i noticed that there is very unpleasant high frequency electrical noise when the volume is pointing 9 o’clock or higher, from both channels. I telephoned the dealer and they couldnt solve the problem.
To find where the problem is, I switched to :
Rega TT - mini a2d phono stage - Brio-R input 2(without phono stage) - Rs3. The noise was still there.
Here is the interesting part. I put my hand on thr chassis of BrioR and then another hand on a metal window frame... the noise is gone.
Earthing issue? I noticed that Rega had removed the earth pin on the power connector of BrioR(there used to be 3 pins on earlier batches of BrioR), so the chassis is not grounded. The reason should be avoiding ground loop or something. Although I can overcome the issue by adding an earth wire connected to the window frame but I dont think its designed to be like this.
Furthermore, it seems to be more than normal current on the chasis - i can even sometimes feel it when touching BrioR, and its continous, not static for sure.
Believe me, i checked tons of threads about similar issue before posting and got no solution.
Is it a defective amp⁇
Or a broken grounding wire in the tone arm as many mentioned?
It is not that easy to request a replacement in China, the dealer is thousands of miles away and they cant really answer the questions. i also dont want to send my TT for fixing without confirming the issue in advance, because i dont want my brand new shiny TT to be ruined with scraches.
I know there are lots of Rega users in this forum - even people from Rega. Hopefully someone can help me spot the problem.
Many thanks.
Now my system is:
Many thanks.
