Welcome to the forum.Hi, all:
I have a Rega Planar 3 and Rega Fono Mini A2D pre-amp. I was looking for advice on what amp and speakers to pair with the turntable and pre-amp. I have not made any changes to the turntable like the cartridge yet. Thanks!
Presumably that's 15 feet?Thanks for your response! I would intend on using the amplifier strictly for the turntable. The room that I am using is about 15x15. The turntable is also new. Please let me know if I can provide any additional information!
That is fine. Are you in the States?Yes, it would be 15 feet. Sorry about that! I would like to keep my amplifier and speaker budget around $800-1000. The types of music will vary, but it will probably be mainly along the lines of jazz and rock. Thanks!
any dealers around you can get to?
Difficult to help too much as what would normally be recommended in the UK may be priced completely different over there.
Your best bet is to look at American products or those you can actually get to see at a local dealer.
I am in the U.S., but we are unfortunately not terribly close to any dealers. Would you happen to have any amp recommendations, not accounting for the difference in price between the UK and U.S.? Thanks!That is fine. Are you in the States?
If you need to keep it for that reason then fineI have an A2D, mainly for digitising my LP collection, not for quality, but convenience, the A2D is not as good as the Naim Stageline, but then it is half the price! I quite like its Naim like sound
