records "jump" after 10 minutes
ram_g
11
hello all
on my technics 1300 mk2
most of my records " jump " after aprxx 10 minutes
its happening with 2 different cartridges and heads so i assume the problem is not there
also tried to add to the tracking force a bit /
but still happening ...
any ideas ?
thank you
ram_g
11
thank you
yes i did .
its always in this specific "area" on the lp
the first half is fine and around the middle it starts to make problems.
like it much more sensitive with numerous different lp's/
all fine till that point on the record.
ram_g
11
whats weird about its that in this specific area on the lp /
if the problem had been with down force and anti skating i would have problems also in the first half ' no ?
abacus
If the arm and cartridge are set up correctly, and the records are also undamaged, then it could be a fault with the arm bearing or cables which are pulling on the arm.
If you move the arm to later in the record do you still have problems skipping, also move the arm across the record by hand (Above the record) to see if you can feel any problems.
Bill
Reactions: scene and Gray
ram_g
11
bias is fine
and also i think the arm ( as i check it manually )
stylus is brand new ( tried it with the old one as well withe a different cartridge )
it becomes most sensitive around mins10-12
after that is relatively fine and later again just around the end of the side .
just worried a bit to dismantle the whole arm
TrevC
It should even with the guard off, this doesn't answer the OPs question as to why it jumps......
:rolleyes:Yes it does, if the arm isn’t free he will have found the problem, The guard on bit is so he doesn’t trash his stylus when he blows it around. I agree with it probably being the trip mechanism, it will likely need to be dismantled and degreased.
I see where you're coming from. I was thinking it would only jump if it had downforce applied
