Hi folks,
After some advice.
My system consists of the following:
Naim Nait 5 Si (2018)
Yamaha RX-A870 AV amp driving centre, sub and rear with front L+R pass through to Naim
B&W CDM1-NT L+R (early 2000's, on official stands)
B&W HDM2 centre (mid 2000's)
Roth subwoofer (cheap replacement for a B&W PV1 that went kaput)
B&W M1 rears (on official stands)
Chord Mojo fed from iPhone/iPad for Spotify/Tidal/.AAC HD audio library, connected directly into the Naim via analogue cable
Rega Planar 1 (Record Store Day edition) + Rega MM Mk3 phono amp (pending Goldring E3 cartridge arrival)
Sony X800 UHD Blu-Ray player
Our room is 20x15ft with the speakers firing across the shorter width.
The CDM1-NT's were bought for a much smaller room and they need a lot of volume to "wake up" and even then lack deep/solid bass and sound too "bright" for me. Interestingly they sound more "musical" via the Rega than the Chord which is a bit odd as I know how great the Chord sounds through headphones (and even on my office/study's "cheap" Denon CEOL N9 driving Q Acoustics 3020i's)
I can only assume my amp/speakers are not well matched. The Nait is definitely "forward" and I'm guessing the metal dome B&W's are too, so 2+2 = 5 or something.
So I'm looking to replace the CDM1's for something floor standing to improve the bass depth and something a little more restrained in the treble area but that will still come alive at lower volumes too, so I don't get complaints from the family
Nothing too pricey, I was thinking about the Dali Oberon 5's (+ will likely replace the centre with the Oberon equivalent). I also have a friend with some old Castle Chester's that I'll try when lockdown is lifted.
Any view on what would achieve the desired effect? Or other options?
Thanks in advance!
After some advice.
Thanks in advance!
