Hi, here is a question that I hope can be easily answered. I am looking for a 5.1 surround system for my tv (well actually I am buying a tv too, but the speaker question is in dire need of answering) and have spotted a set of KEF 2005.2 "eggs" going cheaply second hand, which considering my relatively small budget, seem like a perfect option.
However I understand that these speakers require a good AV receiver. Now, the same guy is willing to sell me his receiver, again quite cheaply, but is a relatively old model - an Arcam AVR200 (which I think is roughly 2002?) Now, I understand that Arcam make good quality equipment, and, unless I am missing something drastic - I believe it will also adequaely connect all my audio needs (5.1 analogue in, stereo in, optical and digital in), and as I have no interest in plugging my video into it - just audio, that works fine...
BUT....
It only runs 70W per channel to 5,1 surround speakers. The Eggs are rated 100W each. Is this a problem? Does this mean the eggs wont work? or wont give their proper sound quality? or will it just affect volume levels but not quality? This in mind, if the AVR is not adequate to work with the eggs, can anyone suggest an AVR that is adequate in quality and power that is also inexpensive as my budget is tight? Bearing in mind that this set including AVR would only set me back about 350 (the speakers are half the sum, the avr the other half) - what sort of money must I spend on an AVR if this one is not good enough?
Many thanks.
BUT....
Many thanks.
