Hi all,
I wonder whether you could help with the following.
My current system is Lossless PC > HRT Music Streamer II > Cyrus 6 > Mission 771s. I also have an Arcam CD72, but the PC is the primary source.
The Cyrus (eBay buy) has recently replaced an Arcam A65+, and I'm so pleased with the improvement this has made to the sound of my system, I'm keen to see whether I can repeat the trick with a speaker upgrade.
My major (non financial) constraint is that each speaker will have to sit within a bookcase cubical measuring 33x33cm, with the front of the speaker no more than 40cm away from the rear wall. I appreciate that this is far from ideal positioning, but two very inquisitive toddlers at home mean that my speaker stands will be staying in the loft, at least for the next couple of years.
The space issue automatically rules out a couple of obvious contenders, the B&W 685 and Kef Q300, which are slightly too tall. Unfortunately, it also appears to limit my options to speakers with rear-firing ports, which could prove problematic given the proximity to the rear wall. That said, my Missions are rear-ported, sitting approximately 18cm from the wall, and I've not noticed any unwanted bass boom from these.
The sound from the Missions is actually pretty good, particularly with acoustic recordings, but what I'm looking for is a more immersive sound-stage, plus the ability to handle denser recordings with equal aplomb. Musical tastes run from Joni Mitchell to Pavement, and everything in between.
Budget is £500 tops, but I'd be more than happy to pay less, and I'm quite prepared to go the used route. At the moment I'm drawn towards a pair of Acoustic Energy Radiance 1's, which are available B-Grade from AE on Ebay for £231 (I really like the idea of grabbing a pair of '£600 speakers' at this price), but other contenders are:
Epos M5i (£230 @ Superfi)
Arcaydis DM1 (£299)
Monitor Audio RX1 (£400)
Rega RS1 (£438 )
EB Acoustics EB1 (£470)
My question is - will any of these or any others in this price range, work in my setup and give me an appreciable improvement over my Missions; or should I hold on until such time as stand mounting is an option?
All suggestions or opinions greatly appreciated.
Arcaydis DM1 (£299)
Rega RS1 (£438 )
