Dear comunity,
I am in the process of upgrading my setup and would love your opinion on the above question. I am a newb but I love music and I have owned a Musical Fidelity Elektra 100, a Rega, Denon, Enaos, Jolida…
This is situation that I am in: till now I have only had part of the complete setup, some good items, other not so good, or a bad listening room. At last I can have all of the elements come together.
Listening room
Refurbished, insulated barn, all woods, 6 x 4 x 2.5 (height) meters
Source
Lossless format or Cds played through computer, with an optical cable directly into the DAC of the integrated amplifier.
Speakers
Polk Audio monitor 60, which i want to upgrade
Amplifier
Jolida hybrid tube-transistor JD 150 1RC, which i also need to upgrade.
Listening style
As an artist, i paint and listen to music for several hours. But I also like to play something punchy for a shorter amount of time and enjoy a fun, lively amp.
Music
Anything from classical, to americana, roots, electro, jazz, etc, ie a total mix.
This is the pickle: the Jolida amplifier is lovely, warm sounding and to me has some character, but it is very old and is breaking on me. So i need to upgrade it. The speakers are fine, but are pretty cheap and sound hollow compared to others that I have tested.
And here comes the setups that I have been testing:
I tried a NAD 3020D, found it OK, nice small format, not very powerful, a bit flat and far away sounding, I didnät feel so much emotional presence and it sounded a bit electronic to me.
The NAD 316 was worse, even emptier sounding i felt.
The NAD C338 was a better, but still sounded a bit flat to me, quite focused, but not dreamy or airy enough, lacking space. It did drive something deeper though, felt more gripping than the two others.
A Rotel RA12 felt precise, to the point and clearer, but i didn’t feel anything in the gut.
Finally I tried the Cambridge Audio CXA60 and just loved it. For me it felt musical, precise, inspired and clear, yet still throttling in the bass. And the notes felt organic, liquid and emotional, with vocal from Joni Mitchell bright and luminous, to the bass of Angus Stone really gripping the belly.
I tried all of the above with the Polks, which were OK, but the DALI Zensor 7s really hit the spot. The Dalis are also white which works in the room and they are OK for my budget, cannot afford more.
Now for the question: I can can get a great deal on the Quad Vena. I have read great reviews on it. Technically, it is a more expensive amp compared to the CXA60…? But I have not been able to test it. What do you think about the Quad? How does it stack up against the CXA60? Similar characters? Will the Quad pair well with the Dalis?
Listening room
Source
Speakers
Amplifier
Listening style
Music
