- Aug 10, 2019
- 2,556
- 5
- 0
hi - I'm considering this but have heard some people say that the best performance is achieved using the direct fixed output and that using the volume controlled outputs from the CD reduces performance significantly. I'd welcome comments about this.
Also, and particularly if there is a performance issue, I'm not clear if this option (i.e. using the fixed outputs) is possible with the 909 which is only a power amp. Be great if someone could clarify this.
