Hi, just moved overseas from the UK to Colombia and need to change my Quad 303 amp to the appropriate voltage so that I can use it. On the back there is a black dial which you should be able to turn in order to have the correct voltage but it wont budge? Am I doing something wrong or do you have to open it up in order to rewire the selector?
Any help and advice would be much appreciated.
