Q Acoustics 2070Si dead frequency range
Jan 24, 2016
I have got this sub working quite well but I woundering if anyone alse is getting vertually no sound between 43hz and 58hz (using a frequncy generation App on my Android) and if there is a setting in the sub to bring this out. The sub can not be easily moved but I dont beleive this to be a room acustics issue as I have moved around and this range sounds dead.
The sound from 30hz to 40hz is fine. The sound from 60hz to 200hz+ is also fine despite saying it only goes as high as 150hz! As the missing frequancy is only a few hertz it is hardly noticable but it is in the region of some low bass guitar notes. The unit has a lots of settings on the back and wounder if it could be one of these combinations.
Hi Johan,
there is no real reason I would know why there is a dead spot in the sub. It might still be a room problem, but could also be a ground loop problem in your setup....your missing range is spot on at 50Hz....that's the frequency of the power line.
Do you have access to another measurment setup? Can you send me the screen shot of what you have now? My E-mail is
finkaudio(at)me(dot)com
Best regards
KHF
