projector screen
I was considering a TV upgrade for next year but have turned my attentions to a projector instead, so im gettying the ball rolling now withe the possibility of pickng up an early 2009 bargain.
can anyone recommend a decent free standing screen that i can pack away when not in use? and also a decent HD projector. Budget i reckon will be around 2.5k.
Clare Newsome
1,657
I found the Draper Road Warrior a great pull-up portable screen before I went fixed - just don't put it (or any) portable screen too near either open doors/windows or full-on radiators (because drafts can ripple the screen).
Add an InFocus IN80 and you're away
Thanks guys
Just on the pull up option, i need to be able to keep my centre speaker where it is, ie underneath the telly so i guess i would need one that wouldnt effect this (ie pull up and across the centre speaker).
or would the centre speaker be ok to be situated behind the screen?
i have a pulldown screen that hangs from the roof via 2 hooks that are barely noticable when the screens taken down.
Thats not realy a consideration for me as i am in rented accom. and i also have very high ceilings. That would be my ideal solution but it just not possible, which is a shame.
I am struglling to find a pull up, acoustically transparent screen at this moment in time.
grrr
