Was going to get the Rega for £248 but have seen that the project is on sale at £299. Is the project worth the extra cash or should I stick with the Rega? Amp is yamaha a-s500 and speakers monitor bx5's.
stevebrock said:Yep project - hearing too many complaints about QC at Rega
paul darwin said:Hi Plastic Penguin,
Not sure about "Sainted" feels more like "Slated" at times.
No manufacturer has 100% reliability, we build and sell over 30,000 turntables pa worldwide and our returns rates are significantly less than 1% which is an enviable rate in our industry. Our inwards and outwards QC is extremely dilligent in ensuring that every piece of Rega equipment that is sold is working to 100% of its potential when it leaves Rega HQ.
Furthermore, what is not stated in some critical posts I have read and investigated is that the problem was caused by transit damage, user error, incompatability, local electrical supply, wiring errors, customer handling and installation issues, etc etc, or indeed when inspected there was no fault found, buyer remorse, change of mind or circumstance etc.
What is really important is in the unlikely event an issue arises, whatever the source or situation, is that it is dealt with promptly and professionally and to the customers complete satisfaction.
I am confident that the support our customers can expect and receive from Rega, or via our distributors and dealers is among the best in the industry. To that end, in an era where some manufacturers are withdrawing servicing support for their products we can also service virtually everything we have built for the last 43 years often at little or no cost or significantly cheaper than others.
Best regards,
Paul Darwin
Rega Research.
plastic penguin said:Local electrical supply: How sensitive are your products? I've been buying hi-fi since 1978 (vastly different brands (Pioneer, Hitachi, Wharfedale, JVC, Arcams, Leema, Garrard to name just a few) and I've never experienced any electrical-related problems
paul darwin said:Plastic Penguin,
Transit damage - when transporting products around the world we do not have absolute control and it is therefore impossible to ensure they are always handled sensitively, our turntables for example should be the correct side up as our packaging suggests. I know from talking to many other manufacturers that problems do on occasion occur and just because they have not been noted here does not mean they do not happen.
Local electrical supply - our products are not especially sensitive but the world over the quality of the mains varies, this can in extreme circumstances affect a components performance and suseptibility to noise from transformers for example, I couldn't comment but others will be able to list brands where this is not unknown. Earthing systems vary enormously. Different equipment in the same system may employ different earthing arrangements. If you route the delicate signals from a turntable to a phono stage in very close proximity to mains cables that can introduce noise. Good housekeeping and dealer experience and knowledge avoids or erradicates most issues
Incompatability - the cases are so many and varied but buying a turntable with a moving coil cartridge when someone has only a moving magnet phono stage would be one example. Not having a phono stage at all and expecting a turntable to work. Under powered amplifier into low impedence inneficient speakers in a big room is another but there are so so many.
User error - user abused and manufacturer blamed is sadly not un common.
Paul Darwin
Rega Resarch
pp? you're coming across as a bitter man. Step back, and rethink this.plastic penguin said:paul darwin said:Plastic Penguin,
Paul Darwin
Rega Resarch
Hi Paul
I totally understand that using carriers is frought with an element of "will my products arrive in one piece or not?". I have the same issues with my small business. Nevertheless the problems I've read are with people who live on mainland UK. That should answer the electrical supply issue.
As regards incompatability, and perhaps people are using MC cart with MM phono stage, isn't that down to your dealers making sure that doesn't happen?
I use Infidelity Hi-Fi in Hampton Wick and I can't ever imagine them selling a Rega product with such schoolboy errors.
Going back to my previous post, amp 'hum' or platter 'wobble', defects with Apollo-R seem to crop up more often than other brands.
About 3 years ago I dem'd at Infidelity (dem isn't actually true. It was already set-up for someone to dem) the Elicit-R with PMC 23s, and it sounded fine. There was no audible issues that Steve experienced a while back.
I'm sure that these problems are very much a minority, nevertheless they can't be swept under the carpet and just say "hey-ho".
avole said:pp? you're coming across as a bitter man. Step back, and rethink this.plastic penguin said:paul darwin said:Plastic Penguin,
Paul Darwin
Rega Resarch
Hi Paul
How a) putting them in context and b) contacting Rega ?stevebrock said:On a positive note I always recommend Rega stuff to newbies starting out - but lately these QC issues are popping up too often if I'm honest.
It may not be a bitter post but it is unhelpful and negative.
Could it be the phono stage ? or could it be the amplifier ? or both ?
Paul Darwin
Rega Research
Unless I am misreading your post, I completely agree, your comments are unhelpful and negative to the thousands and thousands of people who buy, use, enjoy and appreciate our equipment for it's performance, build quality, sound quality, reliabilty, serviceability and even possible resale value, being hand built, UK sourced and with the absolute musicality upon which our reputation is built.
I disagree though, with the advent of social media it appears more and more people are willing to share their experiences and complaints with complete strangers who are often willing to accept their version of events with absolutely no recourse to the truth - that is potentially dangerous to any manufacturer and their hard earned reputation. This, then, if unchallenged, often becomes "the truth" and further damage is potentially done.
By the way, I too, am absolutely passionate about music, musical reproduction and the job that I do and am more than happy to help and advise where it is required, but I can totally understand why the majority of other manufacturers are unwilling to involve themselves with similar dialogue on this and other forums.
Sadly, as a result, this may mean that customers are not getting the impartial advice, support and information they require, and may even be misguided due to certain cynical and malevolent posts from naysayers with no actual experience of the equpment involved whose sole intention appears to be to act, comment and have an opinion on potentially incomplete information and interpret it to support their agendas, present company excepted, obviously.
At the end of the day the only interests should be that the customer / music fan gets the best system he / she can get from whichever manufacturer that maybe and lets hope that it can be achieved without misinformation and bias from any source.
Paul Darwin
Rega Research
