Powered subwoofer, agnostic to the power amp it is connected to?
alessio_m
Is a powered subwoofer completely agnostic to the power amp it is connected to?
I mean, would a powered subwoofer sound completely the same when connected to an entry level consumer integrated amp and when connected to an expensive high-end power amplifier?
shadders
152
89
18,670
Possibly not. I assume that the subwoofer is connected using the power amplifier output, with both channels from the power amplifier (or integrated) connected to the relevant connections on the subwoofer.
If the integrated has less capability than the stand alone power amplifier, and you are driving the integrated very hard, then the distortion in the lower frequencies will be present in the subwoofer output. If the power amplifier has at the same volume less distortion, then this will be reflected in the subwoofer output.
Regards,
Shadders.
davedotco
Regards,
Shadders.
The OP is talking about a powered sub, so presumably driven from the pre-amp or subwoofer outputs. So the power amp is out of the equation completely, small differences in pre-amp (section) would be the only difference, tiny in all probability.
shadders
152
89
18,670
davedotco said:
Regards,
Shadders.
My subwoofer which is powered accepts the output from a power amplifier. This allows you to add the subwoofer to an existing stereo hifi if you have small speakers so as to add bass extension.
Regards,
Shadders.
davedotco
Something of a brainfade on my part.
Thank you for being so polite about my idiocy...*kiss3*
My only possible excuse was in tasting a little of the Christmas port...*blum3*
alessio_m
Yeah i was referring to a powered subwoofer directly connected to a power amp by speaker cables
power amp > powered subwoofer > main speakers
Electro said:
The sub should take on part of the character of the feeding power amp .
shadders, what you say about distortion makes perfectly sense but this is exactly what i'd like to know: if the powered sub takes some of the 'character' of the feeding power amp
Electro
43
davedotco said:
Regards,
Shadders.
I could be wrong but I think he was talking about a powered sub driven by the power amp speaker outputs a la REL Subwoofer ( and others ) .
shadders
152
89
18,670
It's, Ok. I may have long hair, like a headbanger, but there ain't no way its in pigtails.
Regards,
Shadders.
shadders
152
89
18,670
Yes, some characteristics will be replicated. It will be minimal, given the bandwidth that the subwoofer presents - which will be limited - should be less than 100Hz.
Regards,
Shadders.
ASK THE COMMUNITY
