Posting from and iPad
pwiles1968
153
I have found a trick to making posts from and iPad without having your account changed to HTML or whatever it is.
Takes a bit of timing but press the Make Post or Reply buttons, as soon as you see the reply box appear press the X in the address bar at the top of the page do not let it fully refresh, if you get it right you should still see the save button at the bottom of the page and be able to type in the Subject & Body fields, and there you have it.
To prove it this was posted from a Pad.
pwiles1968
153
I have been experimenting, alternatively just disable rich text at the bottom of the page once it has refreshed ? Is that new with the forum update?
Readers of any of my posts may disagree, but definitely an improvement to be able to post from iPhone as well as just browse! ;-)
scene
Posting from the iPad seems fine now, with the "disable rich-text" setting :)
...but using preview resets input to rich text, and when you change it back to plain text entry, it's the interpreted HTML you see, not necessarily what you were typing. Guess I'll have to improve my HTML ;)
visionary
80
I can barely USE the forum with my iPad let alone post.
iPad works fine browsing other sites but regularly crashes on WHF forum as well as "flickery"re-drawing of the screen.
Anyone else had this problem?
Same here - it's a losing battle to use the site from my iPad now, it's a flickery, jittery nightmare - just when you are reading something the screen randomly goes blank and parts refresh. I don't get this with any other sites I visit from my iPad.
Getting to the point that whathifi is rapidly being dropped from the list of daily visited sites (along with digital spy now they seem to force pop up ads at you every few seconds)
Andy Clough
776
It appears to be a problem with one of the ads we're currently serving on the site, which is causing problems on iPads, so our tech team are on the case. Please bear with us while we get this fixed, and thanks for letting us know.
The irony being that it is an ad that is targeted to iPad users only...
