matengawhat:dim_span:Pmaninit:
I'm quite surprised.
Are there no proper systems for properly equalizing a high fidelity playback system?
Obviously many of our listening rooms are less than perfect acoustically. So do people just resort to buying bass shy components? Crazyness.
I have experimented with bunging the speaker ports a lot. I had them bunged for a few months, just to get rid of that spike, but what it actually did was reduce most all bass frequencies. Then one day I took them out and realized what I had done. That is, miss out on good clean bass for ages, just because of the spike in the bass, and as I am happy with everything about the sound apart from that notes interaction with the room, I want to solve it.
There must be something, apart from buy a graphic equalizer that I'll have to find space for, configure myself, and potentially ruin the sound anyway.
like I said .... dump the sub ... dump half of the furniture in your room and you will be fine ... sounds like your room is not ideal (especially if you cannot move your speakers more than 30cm due to furniture being in the way)
or alternatively, get yourself a decent pair of headphones ... problem solved
its not the sub - he said with it off the issues is still there - stop putting down subs they are fantastic for two channel systems when set up correctly! much prefer my standmounts and sub to any floorstanders i have ever used
like I said, a bit controversial, but I personally do not believe in adding a sub to a hifi system ... just my own preference ... that's why I have speakers that have decent bass
