Polk Audio Rti a7 vs KEF Q700
mvg27 said:
Hi friends, Please suggest me which is better speaker system in terms of sound quality for music and movies, Polk Audio Rti a7 or KEF Q700?
Hi mvg27
What source component/s, amplification and speakers do you currently use?
Interconnects and speaker cables are?
What do you and anyone else who is also likely to use the system generally listen to?
The size of your room?
Is the room lightly or heavily furnished?
Distance between the speakers?
Listening distance?
Will anything be in the way of the speakers?
Room floor is (concrete, carpeted, marble,wooden etc.)?
Your general listening level?
Room positioning of the new speakers (distance to walls, corners, will there be anything between the speakers such as a chimney breast, cabinet, windows etc.)?
Your overall budget is?
Your impression/thoughts of your current system are?
With new speakers what kind of presentation are you looking for the system to reproduce?
All the best
Rick @ Musicraft
bemaniac
46
The Q series is bright and natural. Recommend something with a bit of low end clout and high current if you'd like to balance them out a bit. Just my opinion on the q500s I've got.
Frank Harvey
567
To be fair bemaniac, the Q700's are quite different to the Q500's. The larger bass and UniQ drivers produce a warmer, smoother sound than the Q500, which I find are ideal for smaller rooms or those that don't want too much bass.
mvg27 - I can't comment on the Polks, but I can give first hand experience of the KEF's.
As far as movies are concerned, hi-fi speaker's have improved drastically over the last year or so, and the KEF's are no exception to that. Their UniQ driver has always suited movies as they tend to be able to place effects more accurately than conventional speakers, and they have wider dispersion characteristics than many conventional speakers too - more like a dedicated AV speaker.
Their wide dispersion characteristics also allow music to be enjoyed from areas other than the 'sweet spot'. Their light aluminium drivers allow quick response, digging up subtle nuances that some other speakers can only hint at. They seem to have an effortless knack of producing a three dimensional soundstage, something many other sub £1k speakers fail to achieve. The can also project sound into the room, which is even rarer than the previous point!
Because of the capabilities of the Q700, it really does depend on the accompanying amplification as to what you get out of them. They're relatively easy to drive, but they still like to be provided with decent current. Something like the Marantz 6003/6004 ornRotel RA04 amplifiers are a good place to start, and the likes of the Rega Brio R and Audiolab 8200A will get more out of them.
Which amplifier are you intending to use with your speaker choice?
Thank you all for your suggestions. I have finally brought KEF Q700 7.1 package with Polk audio dsw pro 660wi subwoofer and denon avr3312 amplifier. And it sounds great!!
