Pionreer SC=LX81 V Pionner SC-LX85 OR 86 or Arcam? Help guys
Hi all
As some of you may know i recently managed to get my old amp back from my old apartment. I was wondering would the older sc-lx81 be far away in terms of sound and picture quality than its newer brother the 85 or 86 (when it comes out). I am thinking of selling the older one and my Onkyo so that I can get the latest one.
I have the Monitor Audio Silver rx6 speaker set. I am looking for advice on whether it worth buying the new amp. Also what are the best attribites of the Pioneer range v the Onlyo range. I maainly use it for SKY sports etc. Picture quality is also important to me.
I don't really truat the guy in the shop closest to me. He is always trying to sell the Arcam range. Does the technology really move that quickly that an amp that was in in 2009 not sound nearly as good as ther latesst one. Everyone's advice is welcome
CnoEvil
556
14
Which Arcam amp is he trying to sell you - AVR400?.
Arcam major on 2 channel sound, but mightn't have the very latest feature count.....so it depends what is more important to you.
TheHomeCinemaCentre
70
The Pioneer has always been one of the main contenders at the £2k price point and 81/83/85 have all won awards and plenty of praise. The 85 is a step up from the 81 and I have no doubt with the new power modules that the 86 will be a step up when it arrives next week. Tech doesnt move on that much but this price point is fierce so you get more for your money with each generation ( a general rule ).
Onkyo have raised their game as well, a different sound but one that matches with the MA well - the latest 3010 is quite a beast. PQ is probably better from the Onkyo but that will be marginal.
Thanks for the answer. I was wondering do you have any idea what I would be able to get for my Pioneer SC-LX81, Onkyo NR-TX708 and the B&W 685 speaker set if I was to sell them second hand. I really appreciate your help thanks.
Where is your shop in the UK? I live in Ireland but go over there a fair bit on business so I could see if I am close and pop in, Don't worry I won't hold you to a price. I just need to get some idea on the pricing and what I would be able to afford.
Tks
To be honest yes I am. Strangely I found the Onkyo with the B&W 685's better. I keep thinking I am doing something wrong becuase of the reviews that I have read and what people say to me on here.
Another guy mentioned another amp but I never heard of the brand before (MRX range) and would be reluctant to choose it as when I come to sell it I would get nothing for it. I am thinking of getting the Pioneer 86 as it is easily integrated with my mac, apple tv etc. Also Pioneer after sales is very good. I have found the Onkyo to be quite poor in terms of after sales.
As I mentioned my main source of movies is downloading so I know the sound quality compared to BD would not be as good. Sky and bd rips is what I use. Thanks for your help guys. I also do not want a system that is too basy. So what do you recommend? Maybe the guy in my local shop is right, the Arcam.
It seems the MA's are good. I guess I am just not happy with the Pioneer amp. What do other people choose?
BenLaw
475
7
18,895
Anthem does the MRX range, they are very highly regarded and you would have no greater problem selling them second hand as either Pioneer or Onkyo.
What is it you aren't liking with the current sound? There's a school of thought that says Pioneer + MA is rather bright. Whatever it is, IMO changing to a different Pioneer is unlikely to be the way forward.
Can you demo Anthem and Onkyo? Yamaha is the other obvious manufacturer that springs to mind, can you demo them?
Hi Ben I haVe sent out a few emails so going to find out tomorrow. Looking at the Onkyo cause of what u said. All I need is the amp to work in one room. Don't have a cinema room unfortunately. So do u think the Onkyo TX NR 1010 would sound pretty much the same as the TX NR 3010?
Hi breffni
With Yamaha's current Aventage Series on its way out i'll suggest that you also consider the RX-A3010 AV receiver. With the Aventage RX-A3010 you'll gain worthwhile improvements in areas such as audio/video processing, two channel/multi channel music, movies, etc. not to mention that there is great synergy between the Aventage RX-A3010 and Silver RX Series of speakers 8) The Aventage RX-A3010 was already an excellent product at £2k but i would say that it is a bargain at its current general price :)
In my experience Monitor Audio speakers + Yamaha AV amplification form an excellent match (time after time) :rockout:
http://uk.yamaha.com/en/products/audio-visual/av-receivers-amps/rx-a3010_g/?mode=model
All the best
Rick @ Musicraft
lexloofah
8
hi Breffni,
When the LX81 came out i ordered one for home trial over my old denon 4306, and tbh i wasnt happy with the sound from the pioneer/MA (rs6av) combo. It did feel too bright and and seemed to not have enough 'guts', even after a long running in period and using different cables recommended by the retailer. I tried an AVR600 and was blown away by the sound on my MA's exactly the sound i was missing from the pioneer.
But this great sound was at the expense of useability as the arcam has so many problems with lockups and popping and many other grips that annoy me every day. but when it works boy does it work.
hope this helps
lex
UNPUBLISHED BY MODS - DUPLICATE POST
lexloofah
8
hi Breffni,
hope this helps
lex
Although the school of thought also says that MA RX6 is an exception & goes well with the Pioneer. All this is irrelevant if you're not happy with the sound. I agree with BenLaw regarding the need to demo & also the amps that should be on your shortlist.
ellisdj
377
With the risk of sounding like a broken record - make sure you have used mccac properly and set your amp up correctly.
I have posted a lot about this as Its so important - as a bare minimum mccac must be run twice - one full auto then, the one secondary auto run but with your speaker setting saved I.e small 80htz crossover.
If you buy the 86 you will still need to do this / learn to set mccac up properly but it's worth taking the time to do as the results are there waiting for you
If you need help let me know I can point you to instructions I have written before.
Hey all,
So for running a 5.1 system it is worth shelling out 2k on an amp? Thinking the Onkyo 1010? I have seen a post saying go fo the Onkyo 818 as it is just as good? I would gladly buy an ex demo. It seems like people have issues with thevArcam.
Where do I find the mcaac setup.
Today I got offered a grand in sterling for my Onkyo NR TX 708, Pioneer sc lx81 and the B&w 686/686 and the basic woofer and basic centre speaker. It's 10m old. What do you think? I thought it seemed low but not sure.
Tks
TheHomeCinemaCentre
70
A grand is a bit low IMO the 81 is worth £600 at least - more so if you have the box etc and it is mint. I wouldnt get hung up on your re-sale values of the equipment you are about to buy - much better to have years of enjoyment rather than pick an amp you think will hold its value. On that note there is no telling what the market will do when you come to sell.
Your best bet is to find a dealer who you are happy to work with, that will help when you come to upgrade this time and the next.
As for the sound I would check your current system is set up properly and try variations on placement and settings until you get the best sound - upgrade from that point if you need to. The MCCAC is the name given to the calibration on the Pioneer. At the very basic level you should plug the mic in and let it run. From there the settings to tune the sound are vast.
The problem with living in Ireland is that you do not have many to choose from. Will have a look in the mag. If you know of anyone who wants to buy the pioneer let me know. I am speaking to the guy who I bought the speakers off last time. So hopefully he will be able to do something. I will let u know how I get on with the demos.
CnoEvil
556
14
If you are within driving distance of Dublin, there is Sevenoaks (Pioneer) and Clooney Audio (Arcam).
FWIW The AVR 400 isn't as problematical as the AVR 500/600.
If you are near Belfast, try Lyric Hifi (Arcam/Pioneer) or Kronos Hifi (Nad/Anthem)
Bear in mind that trading is not allowed on this forum.
Check House Rules:
http://www.whathifi.com/house-rules
11. The site must not be used to solicit business of any kind – this includes any information in signatures and biographies, and specifically prohibits trade users from linking within forum posts or their signature to their websites, special offers, etc.. Neither shall trade members use the forums to encourage members to contact them for special offers or advantageous pricing.
KiwiMoto
55
Ellisdj please point me in the direction of your previous posts about Pioneer Setup?
I've left my speakers set at Large,and crossover at 100..am I doing it wrong?
Sorry don't mean to hijack the OP!
KiwiMoto said:
Ellisdj please point me in the direction of your previous posts about Pioneer Setup? I've left my speakers set at Large,and crossover at 100..am I doing it wrong? Sorry don't mean to hijack the OP!
You've got a brilliant subwoofer which you're not adequately utilising. Set the speakers to "small", so that your subwoofer handles the lower frequencies.
Hey all I spoke with the dealer of the anthem range and he is going to give me the loan of the MRX 700 for the weekend. So I will check it out. Will let you know how it goes. I am wondering what is the up scaling in the anthem like?
The rep said the closest amp to it would be the Denon 4 something or other. He did not give me a hard sell at all.
Sorry did not mean to break house rules. On the subject I would like to hear people's thoughts on this. I was told that reviews in mags can't be trusted that much as the journalists do not want to damage relationships with advertisers. Personally I always trusted the thoughts of this particular mag. Am I right?
Tks for the tips on the Pioneer it has improved the sound. Tks for everything guys you have been really helpful. FYI Sevevoaks is closed in Dublin
Unpublished - duplicate post
TheHomeCinemaCentre
70
The MRX700 is one of the stand out amps at the price point, very clean and controlled with a great soundstage in stereo and surround. It lacks the facilites of the latest Onkyo's but it will make the very most of your speakers in your room. Is the dealer setting it up for you or are you confident you can get the most out of it?
