pioneer plasma problem
I HAVE A PIONEER PLASMA MODEL # PRO-507PU.
wHEN I POWER ON ALL I GET IS THE BLUE LED OND RED LED LIGHT UP. THEY DONT FLASH. THEY JUST STAY ON. NO PICTURE NO SOUND. I REPLACED THE POWER SUPPLY AND NO CHANGE. CANANYONE HELP? :cry:
Son_of_SJ
325
simonlewis said:
Take it to the tip & buy a panasonic instead.
Wow. Words almost fail me.
Hello six71weiland, I'm not familiar with the Pioneer Plasma PRO-507PU, and I suspect that maybe you are not in the United Kingdom? From the symptoms that you describe, it sounds as if the fault is something pretty major. You've replaced the power supply without success. Maybe it's something like one of the capacitors across the voltage rails. I'm not sure how big your television is, or if it is possible for you to take it to a repair shop that specialises in (plasma) televisions, or whether you can get a repair technician or engineer to visit you at home? All repair options will be cheaper than buying a new television.
Deleted member 2457
6th.replicant said:
And the 2012 award for Most Welcoming and Constructive Response to a Newbie's Debut Post/Query goes to...
Deleted member 2457
Yeah I would check your local newspaper for a TV repair guy, that's what I have always done. They are normally very cheap and should hopefully give you an answer to what is wrong and fingers crossed if not too serious repair relatively cheaply. That is what I would do.
