pioneer bluray bdp 320
I have recently bought the above bluray player to connect it to a 50inch HD Ready Pioneer TV but when I connected up the HDMI cable and tried to get the "Home Menu" to work I cant get any sort of reaction at all. The HDMI connected light doesnt come on either does this mean that the TV which is only 2 yrs old, isnt compatible? I rang Richer sounds Liverpool where I bought and they suggested that perhaps that the the TV wont accept the signal from the Bluray and will need down scaling. Can anyone advise me?
I doubt that there is anything wrong with your TV at all. Are you using a 1.3 HDMI-spec cable?
I had the same problem, you have to press one of the buttons on the contoller its one under the 7 cannot remember what is at work so cannot check think it says video select, doesnt mention it in the manual, i pressed it and the hmdi light comes on .
