Tinman1952
Ok scrub that as the NR1200 does not have Audyssey but it does have bass and treble tone controls and a ‘loudness’ setting. I suggest you try this at very low volumes.
Well that’s strange. The tone controls should have a marked effect on the sound…. you may have a faulty unit then. Can you contact the dealer/seller?When I say 'low' volume I mean 20% or over. Quality improves after 60%volume, but not impressive in any way.. I've not found the 'loudness' setting, but Ive adjusted the tones and the sound modes with little effect.
I've got nothing else to compare it to, and little hifi experience, but it seems to work very nicely with Klipsch RP-600M. No complaints at all. I love the sound and unit itself. Does everything I want and nothing I don't.You may not like what I’m about to say, but you’ve paired a warmish amp with warmish speakers. The Wharfedale 12.2 is most likely not an ideal match for this amp. I would look at Monitor Audio or B&W, or perhaps even a Dali Spektor 2.
I've had the setup for almost a year. I had read or heard that the NR1200 is little dark and the 600's, like all Klipsch, a bit bright, and it seems to be true. I really do like the NR1200. It's 2.1, which is all I want or need or have space for, and it has multiple HDMI's, and adequate streaming capabilities. It really is just perfect for me.Ah you have the NR1200 too? I would also think the RP-600M would pair great with it.
Quote of the year.I'm over 60, and so are my ears .
