Why do you ask ?Very true, and a lot of that comes through trial and error, unfortunately....
Question: did that cartridge you have come fitted or did you go for it yourself?
It's bot normally fitted to that deck as standard as far as I am aware. Just curious if it came with a standard headshell or not.Why do you ask ?
I have the standard head shell still in wrapping .It's bot normally fitted to that deck as standard as far as I am aware. Just curious if it came with a standard headshell or not.
Yeah. When I first wanted to upgrade from a built in, I listened to Rega Fono MM and Pro-ject SB3. The Rega was marginally better than both Pro-ject and built in but by not much at all. The Simaudio Moon 110LP I heard later was the only one that pulled away quite clearly from the rest..I agree with Gray here. I was in on the blind testing and there was little to naff all difference between a stage costing £150 and one costing £600. I've still got one to sell as I'm more than happy with the stage in my Marantz 🙂
To be honest I'm done with buying any more boxes for my system. It sounds great as is... my upgraditis has been cured completely.Yeah. When I first wanted to upgrade from a built in, I listened to Rega Fono MM and Pro-ject SB3. The Rega was marginally better than both Pro-ject and built in but by not much at all. The Simaudio Moon 110LP I heard later was the only one that pulled away quite clearly from the rest..
Contentment - that's the holy grail.To be honest I'm done with buying any more boxes for my system. It sounds great as is... my upgraditis has been cured completely.
All that money spent, yet he still has his turntable positioned right in the firing line of the speakers...Contentment - that's the holy grail.
I was sent this short video tonight by someone that knows I'm into a bit of hi-fi.
Bet this bloke is still looking for better:
View: https://youtube.com/shorts/ydRetDfgICg?si=KAh1Ixj2QirUFxLj
At least he has the amount of vinyl needed to do that turntable justice.
Just because you have money doesn't mean you know how to spend it..... 🙂All that money spent, yet he still has his turntable posistioned right in the firing line of the speakers...
How???? Give me the recipe!! 🤣To be honest I'm done with buying any more boxes for my system. It sounds great as is... my upgraditis has been cured completely.
Sorry to be the bringer of bad news but, I think you need help...my upgraditis has been cured completely.
The recipe is in my signature. This is definitely my end-game system 🙂 The only thing that would get me to change anything would be a component failure🤞How???? Give me the recipe!! 🤣
I think most of the people on here need help... some more than others 🙂Sorry to be the bringer of bad news but, I think you need help...
All the gear, no idea 🤨Just because you have money doesn't mean you know how to spend it..... 🙂
OK I see, great set up! Couldn't see on mobile. How's the KI Ruby?The recipe is in my signature. This is definitely my end-game system 🙂 The only thing that would get me to change anything would be a component failure🤞
I ached with a similar conundrum myself when I repositioned my speakers at the end of the room. The turntable is kinda in the firing line - about 1m+ to the right of my listening chair - it's in a chimney breast alcove, the speakers are toed in slightly and I have a panel resting against the wall at first reflection point but the concern is always there... Sounds good enough but🙃All that money spent, yet he still has his turntable positioned right in the firing line of the speakers...
Absolutely stunning paired with the P3's and the TT15S1. Got both the Rubies during the first covid lockdownOK I see, great set up! Couldn't see on mobile. How's the KI Ruby?
Perhaps, but the OP isn't talking about LO MC cartridges.Correct phono stage can make or break a system. You are dealing with a Tiny Signal Thousands of a volt
LOMC 0.2 mV will need massive amounts of gain 70 dB over 1000% and once information is lost , it is lost forever
