Beginner Question: Turntable for CXA 81 Amp
Surfingdave
10
Hello,
I have zero idea about the best way to connect a turntable. My amp does not have a phono input, and I I understand I need a preamp.
Is there any disadvantage re sound buying a turntable with a built in phonostage vs a turntable and separate preamp?
I’m looking at either the CA Alva TT v2 or a Technics turntable (like 1200 mo7).
Hello,
With so many amplifiers now being produced without phono stages the manufacture of turntables with built in phono preamps has increased.
They are adequate in most circumstances but most can be bettered by a modest separate preamp.
That said the phono stage in the Alva is supposed to be quite good, not to sure it needed Bluetooth though.
Reactions: Integralista
Hello,
Is suggest you can buy the TT V2 with confidence. Onboard phono stage which you can bypass if you buy a separate phono stage later. The Bluetooth is also bypassed if you wish.
The cartridge and tonearm are apparently excellent, the former alone comes in at around £500 if bought on its own. Build quality is excellent.
I've had the Alva ST for some time now and am very impressed with it.
Yes, just be aware it comes with an MC cartridge, which in itself is unusual, and as such you will not be able to upgrade the stylus if it eventually dies.
Alva TT V2 £ 1700 New , Like all chinese TTs they never hold any value
selling for @ under £500 lost 70% in a few years
Running costs Every time you play a record Burn a 20quid note
Alva MC will wear out and need replaced as fixed stylus @ £ 319 will cost 70% of the TTs value
Try sending this back to china for a re-tip/rebuild
2022 They where £500 New , 2025 now £319 buy the time you need to buy one could be much cheaper again
Technics/Project/Rega all hold values much better
Reactions: nopiano
Agreed regarding the value of the decks you mention but if buying as a keeper and not too concerned about resell value then the Alva, at its current price, is the better deck when compared to price equivalent turntables from other manufacturers.
Admittedly at the RRP of £1699 it was overpriced.
Well, someone's breetches are chafing today...
Okay, so John Darko rated and used the Alva TTv2 for a while last year and rated it. I picked up the Alva ST a couple of years ago and fit and finish remain excellent. Sound quality likewise.
Build quality exceeds the likes of Rega's P3 and up to the midrange Projects likewise. Both of which are pretty much gloss MDF and in the Rega you pay for the arm and the motor and that's the bulk of it.
As for where they're built, neither here nor there. The hiring company sets the quality assurance standards in the body of the contract with whoever the sub-contractor is. So regardless of where you build the gear, the build standard is set in stone. This is borne out in practice, and in my experience, lives up to it.
As for residual down the line, who cares? If you keep it for 10 years then you're good to go. And of course Technics and Rega residuals are higher; they've been making turntable for far longer. Cambridge by contrast are lucky if they've got four years under their belt (drive). I look forward to seeing their future decks.
All of the above is where I'm at. YMMV.
To the OP: as previously stated, buy with confidence.
I must admit I have never bought a turntable with the future resale value as a factor in my auditionings.
The hifi world is a fickle place and it only needs vinyl to drop back out of fashion and your turntable is going to be worthless anyway.....
Depends what you buy Al
1954 - £19
Garrard 301 launched in 1954, the base unit (motor + platter, without plinth, tonearm, cartridge) was priced at £19 plus £6 3s 6d purchase tax
2025 - £51,645
1954 - £19
2025 - £51,645
I don't see your point I am afraid.
What exactly are you saying?
My point was nobody should go out and buy a turntable these days with the assumption it will go up in value.
Nobody is surely going to believe buying an old turntable that might still be going in sixty years and then slapping it in an expensive plinth and attaching a great tonearm will be a sound idea?
Especially when they then think its worth 51k?
I'm out as we are straying too far from the OPs question.
Reactions: RoA and record_spot
Thanks all for the input . The Alva TT v2 does indeed sound like a good option, the direct drive version is on sale here for £ 850.
While the Cambridge is an interesting design, I’m inclined to go with the Technics, Rega, Pro-ject suggestions here.
In particular, as you mentioned direct drive positively, the Technics is a no brainer. Not the old 1200 you mention, but a newer SL1500 with the built in phono stage to get you started. Then an upgrade of stylus - assuming you get the Ortofon fitted there in Australia. But, the $64,000 question, what is your local price?
Better models are available if budget permits.
Reactions: RoA
Superb decks. Technics have raised the bar with their later turntables and improved direct drives. I have a 100C in black (1500C without built in phono stage).
Reactions: nopiano
Cheers. SL1500Cs, with an Ortofon 2M RED cartridge, look to be £895.
£50 more than the on-sale CA Alva TT v2.
Reactions: nopiano
Agree with the above, the Technics is a superb turntable. I had it and just upgraded to the considerably more expensive SL1300G - did some A/B before dropping the SL1500C off to its new home and it really held its own, which is remarkable considering the nearly £2k price difference.
Main thing to bear in mind - sell on the Ortofon Red and get a better cartridge!
I had in mind a Blue stylus upgrade might be the next step…but any AT VM95 series is a good bet too.
Reactions: Entrigo
