Yes it is.I want to know if it's possible to connect it to a 'modern' sound system?
Are you sure they are outputs and not inputs? The deck has an amplifier in it.Yes it is.
Try this (available in 4 lengths up to 2 metres).
Plug it into the upper (tape) output, then connect to a line or 'aux' input of any modern amplifier.
You may need to have the amp volume control a bit higher than with other, 'modern' sources, but that's no problem:
If that doesn't work, try the lower socket (you can do no harm).![]()
kenable 5 Pin Male DIN Plug to 2 X RCA Phono Plugs Audio Cable 1m for sale online | eBay UK
Find many great new & used options and get the best deals for kenable 5 Pin Male DIN Plug to 2 X RCA Phono Plugs Audio Cable 1m at the best online prices at eBay UK! Free delivery for many products!www.ebay.co.uk
Let us know if neither work and whether you've got a soldering iron (as it's possible that a couple of wires might need to swap pins in the DIN plug).
Those old DIN sockets can be in and outs at the same time.Are you sure they are outputs and not inputs?
I know, one is tape the other tuner but are they output?Those old DIN sockets
...I pressed 'post reply' prematurely by accident on my phone 🙄I know but are they output?
Yes, one for a tuner will only be an input.I know, one is tape the other tuner but are they output?
the Tuner would suggest they are inputs.
Then possibly they both are.....Yes, one for a tuner will only be an input.
Do your parents still have the manual?Hello fellow HiFi enthusiasts,
To get straight to the point:
I got a Philips 660 turntable from my parents and I want to know if it's possible to connect it to a 'modern' sound system?
I hope you can help me.
Best regards,
Rexanthony
My thinking also.Is there a switch on the unit saying something like "Source - Tape" such that you select between the two? If so then the 'Tape' socket on the back is for both output to record and input to play from a tape recorder. It was quite common though trying to solder up 5 strands of cable was fun to say the least. If it does have an output then you only need a lead for the output which will need three pins connected (L,R and common) to two phono plugs on the other end and various sources can supply this or make one for you. Just make sure you order a lead for output from a 180 degree Din socket to phono input on the amplifier.
If there is no Source/Tape switch then it's likely that the socket is input only in which case I doubt you can connect it to a modern amplifier.
He can try it, it's cheap, but as my reply to Roger indicates this may not be possible.That's what the lead is that I've linked to above Roger 👍
Really couldn't be cheaper.He can try it, it's cheap
getting it open may be tricky, however it certainly isn't going to avoid the warranty 🙂Really couldn't be cheaper.
But if he doesn't want to risk £2.65 😱, seems to me he's got 2 viable options.
Do as you suggested, come up with a user manual, to stamp on the uncertainty. Or, do what I would do: open the unit and look at the back of the tape socket. It will have wires soldered to a minimum of 3 of the 5 pins. If wires are soldered to all 5 pins, then it definitely has an output. No question.
let's hope the OP responds...Instructions are available on Vinyl Engine.
From a quick look it seems I was wrong and you could use the tape socket with pressing some buttons to give a variable out.let's hope the OP responds...
How lucky she is, to have such a thoughtful brother.(passed it on to my sister) when I realised how expensive, and often poor quality (from what I’ve read), modern vinyl is.
The service manual is at link if that helps:Really couldn't be cheaper.
