Hi
Right, the main differences between a G10 series to a V10 series is:
V10 has: DCC (Digital Cinema Colour) this gives you better colour reproduction on Blu Ray movies, V-Audio Pro Surround which is Panasonic's better sound speakers built in, THX certification and has a preset THX mode calibrated into the TV, Viera Cast which basically is a few online services built in like e.g. YouTube but you will need a hard wired ethernet cable to pop into the TV, 24p Smooth Film which runs basically smoother than the 24p playback on the G10, DLNA for networking your PC to the TV for streaming and also the V10 is very stylish, it has one sheet of glass in terms of the display instead of the usual plastic frame around the screen found on the G series, oh also.. it is 2 inches thin too.
There is the G15 series too, the only difference between G10 and G15 is that the latter has the same sound as the V10, has the networking and Viera Cast capability and last of all it is 24p smooth film not 24p playback.
The choice is yours, G10 is affordable, G15 is a little more and the V10 is a bit more but has everything going for it.
Regards> M
