Panasonic TX-32LXD700 or Panasonic TH-37PX80?
I am looking to buy either of these tv's, or maybe the Sony 32d3000? I will be watching from a viewing distance of about 2.5 / 3 metres. Probably mostly SD TV, and some HD through Sky HD. Picture quality is the most important factor. I'm switching from a CRT TV which although is only SD has a much more pleasing picture then I have seen on any LCD or Plasma TV yet. Picture break-up from motion smearing, noise, and artifacts from processing are all a big concern. Also I would like to be able to adjust the picture setup in detail. To stop High-lights getting burnt-out and clipping, and crushed blacks resulting in a lack of detail in the blacks. which I've seen all too often on LCD and Plasma screens in Electrical shops. Please Help!
Hi there
Just to let you know, there are literally dozens of posts on the issues you've raised here on the forum. Best bet is to use the search facility and type in your model numbers and you should get a wealth of information from people commenting on them over the last few weeks.
Hope this helps!
