That doesn't apply because I bought used second hand without the manual.The manual might have explained that the volume is displayed as you describe
I rest my case....That doesn't apply because I bought used second hand without the manual.
Don't be put off. I started 25 years ago with a Denon mini system and knew nothing about HiFi. I enjoyed it so much it inspired me to learn more. Over the years I have owned many, many top brands of HiFi components and speakers. The important thing is to enjoy the learning process, not exceed your budget and enjoy the music. I wish you many years of increased knowledge and enjoyment. 🙂That doesn't apply because I bought used second hand without the manual.
Forgive me but another unnecessarily acerbic comment to an absolute beginner....I would suggest everyone who spends out whatever money on a system fully investigates how it works before purchase.
whatever the volume displays you know whether it is loud enough......
I doubt it as tried looking online at the manual and doesn't seem to mention anywhere.The manual might have explained that the volume is displayed as you describe.
my Sony Home Cinema amp does the same thing but I knew that....
To be fair, it's not the sort of thing a manual would necessarily explain - and it's clear you didn't understand the first few explanatory posts (you said so) No problem.I doubt it as tried looking online at the manual and doesn't seem to mention anywhere.
Ignore the comment about getting a decent hi-fi 🙂that was a bit ridiculous - some of the world's best hi-fi displays volume in the way your Panasonic does - and the faders on the mixing desks that record the music.... they're marked in the same (-dB) way.
I'm guessing that you might have just missed the minus symbol in front of the figures and noticed only decreasing figures as you increased the volume!
That minus is the crucial thing
That's all you need to understand. That convention is to treat maximum as 0dB, then display how much lower the volume is with a minus figure so the lower you go the higher the minus figure.
Some amps display it how you've got it.
Some display it how you'd like it.
Some let you switch between the two forms of display.
Mine uses a ring of LEDs around the volume control, which suits me - too bad if it didn't.
-40dB will be louder than -50dB.I'm guessing that you might have just missed the minus symbol in front of the figures and noticed only decreasing figures as you increased the volume!
NOT SURE WHAT YOU MEAN BY THE MINUS IS THE CRUCIAL THING?
Exactly. You see the two dashes before the 44dB? That is the minus sign.Photo of my hifi system
yes i see it but volume is confusing at the end of the day agree with me!Exactly. You see the two dashes before the 44dB? That is the minus sign.
It's only confusing if you have never encountered it before 🙂yes i see it but volume is confusing at the end of the day agree with me!
Yes it may seem counter intuitive. I remember being surprised by this when I bought my first Denon AV receiver many years ago. You just have to remember you are coming DOWN from zero (maximum) so the numbers go negative and increase as the volume goes further down from zero. You soon learn what is the level you like.... Welcome to the crazy world of HiFi 😁yes i see it but volume is confusing at the end of the day agree with me!
As you have seen certain numbers can go up, other numbers can come down 🙂 Hi-Fi is a mad world my friend 👍
my system doesn't seem to come down from zero?Yes it may seem counter intuitive. I remember being surprised by this when I bought my first Denon AV receiver many years ago. You just have to remember you are coming DOWN from zero (maximum) so the numbers go negative and increase as the volume goes further down from zero. You soon learn what is the level you like.... Welcome to the crazy world of HiFi 😁
now i see!As you have seen certain numbers can go up, other numbers can come down 🙂 Hi-Fi is a mad world my friend 👍
Well if you turned the volume up to max it should get closer to zero... .but I wouldn't recommend this in case you destroy your speakers...(or eardrums!)my system doesn't seem to come down from zero?
Without wanting to sound acerbic that is an odd question that will only get one or two types of answer neither of which can really help.is panasonic a good brand for hifi and sound qualitty?
Nice...😁Without wanting to sound acerbic that is an odd question that will only get one or two types of answer neither of which can really help.
I have owned Panasonic kit but only of the home theatre variety, this did the job as well as expected.
yes it's pretty loud 🙂Well if you turned the volume up to max it should get closer to zero... .but I wouldn't recommend this in case you destroy your speakers...(or eardrums!)
