Panasonic 50vt30 Power Issue
Hi All
I have the above Tv and need to extend the power cable in order to wall hang it. Unfortunately, it does not use a standard kettle connection- anyone else got round this? Just had my walls skimmed so moving power sockets isn't an option!
toyota man
79
Hi Jlynch1984 I think the way around this problem is to use an extention lead or cut the mains lead so its adout 600mm long and use a 13amp line connector and connect a longer lead as long as required with a 13 amp plug top on it a bit of a fath I know but I am not sure trying to replace the lead would be a good idea you local tv shop might do it for you be carefull though if its a new tv as it will affect your warrenty
Oldboy
421
Have you contacted Panasonic for advice on extending the cable?? I would not want to cut the lead unless it's a last resort but i do find it strange that the tv lead isn't long enough, i presume your sockets are some distance from the tv then which would mean you could run a simple extension lead to the socket and connect the tv to that although it will look a little messy.
If i remember correctly the GT30 i had did have a strange connection into the tv but i think it's just a safety feature to stop the lead being pulled out, i'm sure there will be a standard connection underneath it if it's the same connection but i would seek advice and contact Panasonic.
Apart from running an extension lead or cutting the power lead i can't think of any other way around it, i have the same issue and killed two birds with one stone and bought a tacima mains conditioner lead that extended to my kit rack and i plug into that with the bonus of decent power supply now getting to my kit. I've got plans to mount that to the wall and box it in so i can isolate all the power cables from all my other cables when i get the time and motivation.
Hi- thanks for the reply.
So I cut the cable (can it be before 600mm from the tv end?) and put it into the connector and the get a much longer cable and connect it to the other side of the connector?
toyota man
79
Mon, Aug 13 2012, 4:07PM#3 Jlynch1984 OfflineJoined: 13/08/2012Posts: 2RE: Panasonic 50vt30 Power Issue
Yes and yes it can be but its best not to make it to short .I think if I was in your posistion I would go for an extention lead:)
