PA system install (mono)
fitzyboy2000
42
Good Morning
http://www.electrosupplies.co.uk/Public-Address-Complete-PA-Systems/c6_491/p6392/Compact-100V-Wall-Speaker-Kit-with-Amplifier-&-50m-Cable/product_info.html
I am installing this system into a factory for a friend, and need to know the best way of wiring it. We will be using 2 core pa system cable and it will be a mono setup so does that mean you can loop into 1 speaker then out of that into another or do they all go back to the amp???
Thanks....
The specs read like the speakers would loop from each other...but surely the manual covers installation?!
I have no idea - as I said, all I did was read the specs on the website link you posted.
If I were you I'd read the installation instructions in the manual.
