ok looking for the cheapest price for a Oppo 203 have roughly looked around the internet but no one seems to budge of £650 if I could find one for £600 I would be happy with that .
thanks I think your right on uk prices I phoned richer sounds up they will only more on price if I buy something else with the Oppo 203macdiddy said:however a search on ebay does come up with one possible option of getting it cheaper:
http://www.ebay.co.uk/itm/Oppo-UDP-203-4K-Ultra-HD-Blu-ray-player-with-Wi-Fi-/201814259585?epid=233055795&hash=item2efd113781:g:RBkAAOSw9GhYcT6j
*music2*
Blacksabbath25 said:ok looking for the cheapest price for a Oppo 203 have roughly looked around the internet but no one seems to budge of £650 if I could find one for £600 I would be happy with that .
I did big boss already I phoned him this morning but I think David would struggle to get one under £649 as well and to be honest I had no player since taking the Sony back so wanted to get something sorted out fast so I went and brought one .bigboss said:Speak to David @ Little Audio Company.
i have one now mate and i feel its worth the money i paid its miles better then the Sony X800gel said:Frank Harvey and Al give the best discounts on the Oppos.
no the uk version of the Oppo 203 will only play uk Pal formats but there is a bit of software you can download from the un-official Oppo website so I was told you just download it on to CD-ROM and then put CD-ROM disc into the Oppo which then turns the player into multi region but weather this is true I do not no but that is what I was told .Benedict_Arnold said:Forgive me if I'm wrong, but I THINK all 4K BDs are region free anyway and most manufacturers gave up "region-ing" regular BDPs and DVDPs some time ago.
Blacksabbath25 said:Well most of the blu-rays And 4k films I buy of amazon have the U.S coping warnings from the federal government which are regional free copy’s so I’ve kind of confused myself here as it used to be regions 0 , 1 ,2 3 what I remember .
but there differences between the U.S Oppo 203 which is multi And the UK version which is not as I’ve seen the mod version £745 and the standard version at £649 http://petertyson.co.uk/index.php/oppo-udp-203-multi-region-4k-uhd-blu-ray-player.html?gcpc&gclid=Cj0KCQjw1JbPBRCrARIsAOKj2PnEUfbvmUUGY-CTuoRzLCS1dpV7khvE6PmJ0GujoyuxBsNkW06Q2hYaAjhOEALw_wcB
and standard version.... https://www.richersounds.com/oppo-uhd-blu-ray-player.html
Samd said:Almost non-event though as most BD and many DVD (discs themselves) are region-free?
the uk Oppo is locked unless you buy the unlocked Oppo for £750 but I was told on the unofficial Oppo site you can download the unlock softwarebigboss said:Samd said:Almost non-event though as most BD and many DVD (discs themselves) are region-free?
Depends. There are a few US only region locked releases, if you're interested in them. Also, many people prefer to import discs from the US if they're released early there or are significantly cheaper. In that case, better to confirm if the blu ray is region locked or not.
DVD region locks can be unlocked by software, but blu ray region locks require a hardware modification (hence about £100 more expensive).Blacksabbath25 said:the uk Oppo is locked unless you buy the unlocked Oppo for £750 but I was told on the unofficial Oppo site you can download the unlock softwarebigboss said:Samd said:Almost non-event though as most BD and many DVD (discs themselves) are region-free?
Far cheaper and simple if you do it yourself.bigboss said:DVD region locks can be unlocked by software, but blu ray region locks require a hardware modification (hence about £100 more expensive).Blacksabbath25 said:the uk Oppo is locked unless you buy the unlocked Oppo for £750 but I was told on the unofficial Oppo site you can download the unlock softwarebigboss said:Samd said:Almost non-event though as most BD and many DVD (discs themselves) are region-free?
You can do it yourself if you want:
http://bluraychip.dk/product.php?id_product=31
Why? Unless BS has zone A blu ray discs or region 1 DVDs, it's not really needed. Besides, he can make his existing player multiregion for only £60 (via the link I sent). It's easy.gel said:Return it to Richer Sounds and buy the multi-region one instead.
hi gelgel said:Return it to Richer Sounds and buy the multi-region one instead.
