Ooops. Speaker set up is wrong!
Soopafly49
104
Just reading the the B&W 686 manual and realised they are set up wrong. It says the cable should be plugged into the HF not the LF and the connectors should only be removed if biwiring. Ooops. This wont have done anything to damage the speakers will it? correcting the problem now?
Big Chris
400
If you were connecting to the LF terminals and had the jumper bars removed, your tweeters were doing absolutely nothing!:O
I'm betting it sounded quite flat and lifeless. You won't have done any damamge though, and I bet it sounds much better now!
