Onkyo 875 bi amping question
Already have an 875 bi-amped to a pair of IQ5se, using a cyrus cd6s. If I were to add a 8vs2 for stereo listening only via the preouts as discussed in variouse other threads, would I have to change the way my speakers are conected. As I said they are currently bi amped.
Since the Cyrus amp will take over the amplification of the front left and right channels, yes you'd need to dispense with the current biamped set-up - unless, of course, you bought an additional power amp to use with the Cyrus.
would the speakers remain connected to the receiver or the amp? In your opion whch is best the 875 biamped or the 8vs2 single connection option?
You would disconnect the fronts from the Onkyo and hook them up to the Cyrus. Not a clue on the second part I'm afraid, though my gut instinct says the Cyrus will be better.
