Onk. 805 reset code?
nads
Any ideas? As most of the remote is oing nothing. It did and then stopped.
I know it s not the remote as I can turn zone 2 on and off and the logitec remote has the same lack of effect.
Any ideas? I will have to download. Manual as I am not sure where mine is after the move.
professorhat
992
22
18,895
Worth checking if it is the remote - I've seen some previously where some buttons work and some don't. The easy way to tell is to use a digital camera or camera phone - point the remote towards it and press the buttons and see if you see a flashing coming out. If you do, you know the remote is okay.
nads
like i said it is not the remote as i can get zone 2 working and the Logitec remote has the same lack of results.
also the remote was working as i was setting up the playback setting and then ................
so any reset codes?
Andrew Everard
1,878
Bearing in mind this will clear all settings, hold down the 'VCR/DVR' selector button on the front of the amp, then press 'Standby/On' button. This will take the amp back to factory defaults.
