Odd ball question. Coax cables as interconnects?
nads
887
239
19,270
Any reason why not to?
I seem to have a glut of QED coax interconnects.
yes I could plug them and see but I thought I would ask first whil I plat with some old Supra HDMI cables and 4k!
abacus
976
668
19,770
COAX interconnects are usually 50ohms impedance so are not suitable for standard interconnections which require low impedance/resistance cables.
Bill
Gray
The vast majority of interconnect cables are coax(ial), although I've got a Kimber weave type (no I didn't buy it and no, it makes no difference to the sound).
Though intended for fixed installation, CT100 type satellite cable makes a good interconnection cable not least because of its near 100% braid and foil screening.
OK if you rarely move it, personally I never do.
