DougK said:Nagaoka can be purchased from a multitude of UK suppliers, it's the recent price hikes that are the sting in the tail.
avole said:They need replacing after relatively few hours. Home use reference time, according to the Nagaoka manual, is 150 - 200 hours, which makes them untouchable as far as I'm concerned.
I'd look for the recently discontinued AT440mlb or its replacement, the VM540ML.
brownz said:When I first got my 2-Xperience I tried a 2M Blue stylus on the fitted 2M Silver Cartridge and it was a bargain upgrade. Definately took the edge off the brightness of the 2M Silver and gave more sepeartion to the instruments. I ran that for around a year before upgrading to a 2M Black Cart (It came along at the right price). I only ever get to listen to Ortofon so can't comment on anything else. Ducks and runs for cover in case the Ortofon has been thrown back into the mix :-D
Hi brownz, I see your employer has renamed itself Henley Audio - presumably because you don't design anything these days?brownz said:When I first got my 2-Xperience I tried a 2M Blue stylus on the fitted 2M Silver Cartridge and it was a bargain upgrade. Definately took the edge off the brightness of the 2M Silver and gave more sepeartion to the instruments. I ran that for around a year before upgrading to a 2M Black Cart (It came along at the right price). I only ever get to listen to Ortofon so can't comment on anything else. Ducks and runs for cover in case the Ortofon has been thrown back into the mix :-D
nopiano said:Hi brownz, I see your employer has renamed itself Henley Audio - presumably because you don't design anything these days?brownz said:When I first got my 2-Xperience I tried a 2M Blue stylus on the fitted 2M Silver Cartridge and it was a bargain upgrade. Definately took the edge off the brightness of the 2M Silver and gave more sepeartion to the instruments. I ran that for around a year before upgrading to a 2M Black Cart (It came along at the right price). I only ever get to listen to Ortofon so can't comment on anything else. Ducks and runs for cover in case the Ortofon has been thrown back into the mix :-D
I'd definitely choose an Ortofon at the price you probably pay! ;-)
grimharry said:*biggrin*You not suggesting a bias?
Al ears said:brownz said:When I first got my 2-Xperience I tried a 2M Blue stylus on the fitted 2M Silver Cartridge and it was a bargain upgrade. Definately took the edge off the brightness of the 2M Silver and gave more sepeartion to the instruments. I ran that for around a year before upgrading to a 2M Black Cart (It came along at the right price). I only ever get to listen to Ortofon so can't comment on anything else. Ducks and runs for cover in case the Ortofon has been thrown back into the mix :-D
Unfortunately at £135 its not a cheap option to try and then find you don't like it......
Time to toss a coin, or do you plan to audition some?grimharry said:No not yet. But do you think it would be a significant improvement on the 2m silver?
grimharry said:Benz micro gold that's 4 now *biggrin*
nopiano said:Time to toss a coin, or do you plan to audition some?grimharry said:No not yet. But do you think it would be a significant improvement on the 2m silver?
It is, but there's the similar Benz Micro Silver, which is high output and can be used with an MM input.DougK said:grimharry said:Benz micro gold that's 4 now *biggrin*
I'm sure someone will correct me if I am wrong but isn't the Benz a low output MC cart? Do you have an external MC stage or does your amp have both MC and MM stages?
