Thompsonuxb
- Feb 19, 2012
- 125
- 0
- 0
I'll bet it blows the Cyrus out the water on every level - make sure you set it up though.
Go into settings set the main speaker levels to max and speakers to large. Turn off unused channels set LFE to main.
Those amps are digitally attenuated I own the rx-a1020 don't worry you have to turn them up abit from -40db on the volume dial.
If you want you can try the bi-amp feature.
The other tip - if you have a digital out on your player use it or use your blu-ray, try the source direct button too.
This thread just became exciting. I look forward to the outcome...lol
Let us know your findings.
