altruistic.lemon said:Room interaction can't make the bass lower than the speaker can produce. It can sound full, controlled, boomy etc, but it can't be lower that the driver can produce. It's that that is the problem - my speakers don't do real low bass, but the bass sounds more than sufficient in my room.
Yes, but with an 8" bass driver in a large(ish) cabinet of 31" (Height) x 14" (Width) x 10.5" (Depth) with a wide baffle compared to most modern loudspeaker designs (the cabinets are wider than they are deep).CnoEvil said:altruistic.lemon said:Room interaction can't make the bass lower than the speaker can produce. It can sound full, controlled, boomy etc, but it can't be lower that the driver can produce. It's that that is the problem - my speakers don't do real low bass, but the bass sounds more than sufficient in my room.
Audio Note AN/E go as low as 18 Hz (at -6 dB), which I don't think is possible without room interaction...but I'm no expert.
chebby said:Yes, but with an 8" bass driver.
chebby said:That, and it's 95dB efficiency, would ensure significantly deeper bass than a 4" driver (with some 'piston' area already lost to a concentric tweeter - as opposed to a dust-cap - in the case of the Tannoys) in a much smaller and thinner cabinet with hardly any baffle area to interact with compared to that of the AN-Es.
Thompsonuxb said:Brib7 said:These minituare Tannoy's have 4 inch drivers and only go down to 67 Hz apparently, they cannot reproduce deep bass, they just won't move enough air.
thats the thing, your talking about 'shifting air' thats volume, its not frequency range
Brib7 said:
miggyboys said:Also, don't forget, the Tannoy Dual Concentric design also means that the tweeters don't quite fill the room and create as wide soundstage as standard dome shaped tweeters, thus the speakers overall will have a tighter, more directional sweetspot (as you've found by repositioning them).
miggyboys said:CnoEvil and The Record Spot - interesting you both say that, and it could be true. I'm just going on a review (which is just one person's interpretation of course, albeit a very experienced reviewer of loudspeakers):
HiFi Choice:
One key characteristic of the DC driver’s horn-loaded tweeter is that the treble is focused into a 90-degree cone, rather than the much wider dispersion shown by most speakers with conventional dome tweeters. This is neither ‘right’ nor ‘wrong’, but it is ‘different’; sharpening the image precision and focus, but diluting the illusion that musicians are in the listening room.
Also, please note, I wasn't talking about the overall soundstage - just the tweeter...I should have written: thus the tweeters will have a tighter, more directional sweetspot.
BenLaw said:Thompsonuxb said:Brib7 said:These minituare Tannoy's have 4 inch drivers and only go down to 67 Hz apparently, they cannot reproduce deep bass, they just won't move enough air.
From any other poster, this level of ignorance would be staggering.
BenLaw said:Driver size is absolutely related to the frequency that it can produce. By your rationale a 1" driver could go as low as an 18" driver, just it would be quieter. That is what I was describing as ignorance.
