- Aug 10, 2019
- 2,556
- 5
- 0
Good:-
I have found that the speakers that come with this system are actually very good, slightly better in my opinion than the Tannoy Mercury F1 Customs, giving a warmer sound
The system is well made with very good sound quality, but it depends on how good the source material is in the first place, but I believe this applies to all hi-fi no matter what the price is, I presume this is correct as the end result is only as good as what goes in
Nice small compact size with amp/cd/dab tuner/fm & mw tuner
Its got very good connectivity for different media:- usb/ipod/mp3 players/mp3 cd/wma cd
Bad:-
Major point, the volume control has not got enough discrete steps to adjust the volume to the desired level, you are left with having one setting too low and the other too high, the range is from 00-45 where as for example the Arcam solo mini has 00-75, hopefully I will get use to this in time, how can they make such a basic error on this otherwise very good product
Very minor point, the speaker connectors on the back have not got proper spade connections
Bad:-
